ulkucu_hareket
Member level 2
Dear friends has anybody have a project which is relation scada with Labiew ?
soundar said:With LabVIEW you can create a SCADA for PC, a PC Based Automation. NI is providing LabVIEW support for their Programmable Automation Controllers (PAC).
If you want to interface the PLC, check the port connectivity and command structures or drivers.
LabVIEW can provide a High End Front End and Functionality in terms of signal analysis.
khongai said:Both Labview and WINCC can connect to other PLC through OPC sofware.
And WINCC seem powerfull and flexible than Labview.
