DDavid
Full Member level 5
Hi guys,
I got some problem: I have duplexer for CDMA (UL 824MHz - 849MHz & DL 869MHz - 894MHz). My duplexer has about 90dB isolation is not enough for me so I decided to put Saw filter after Duplexer to increase isolation. Important to indicate that after Saw filter I have LNA.
So I did it, and I was expect for isolation at least about 120dB (Saw filter => 40 dB [EPCOS]).
But I was disappoint Saw filter as if no exist I got only 90dB from duplexer that all!!!
W H Y???????????
SAW filter according to the datasheet said that Zs=Zl=50Ω. So Saw filter suppose to be macthed. I check with Network I have above 10dB Return Loss. Dulpexer have much more and so the LNA.
I can't understand and truly don't know what to do!
Tnx a lot
Regards
David
W H Y???????????
Tnx a lot
Regards
David
