Sampling DAC output with an ADC
beauch10
Newbie level 3
Hello,
I'd like to sample my DAC output with an ADC in the oscilloscope. When I do this, I will get some data in Excel with two columns - one being time, and the other being the corresponding quantized output voltage.
My simple question is this - for a particular (time, Vout) pair, how can I tell exactly which code was used as input to the DAC? I suspect there has to be some sort of synchronization scheme? What's the best/easiest way to do this?
Thank you.
Dan
barry
Advanced Member level 5
California, USA
The simple answer is you can't. You would need to look at the input signals to the DAC. It could be further complicated by pipeline delays, etc.
KlausST
Super Moderator
Staff member
The DAC surely needs an input.
Who/what controls this input?
Best is if you have access to the DAC inputs and you can send a test pattern to the DAC.
Klaus
barry
California, USA
Not sure what you're trying to do, but you could just put a static value on the input to the dac and then monitor the adc.
beauch10
Newbie level 3
Klaus
I have access to the DAC input. I'm trying to obtain the transfer curve of the DAC. I then want to invert this transfer curve to populate a pre-distortion LUT. It's easy to do a dc measurement of the transfer curve, but the transfer curve changes when I go to higher frequencies. I want to be able to obtain this transfer curve using a signal around the frequency of interest.
Dan
