sampling an slow freq timer after fast stobe - hard problem detailed below
pruki1
Newbie level 3
Newbie level 3
i have a very hard problem
there is a timer that is clocked by clock_S
while someone sends a 1 cycle strobe at clock freq X
need to supply a valid value of timer after maximum 4 X clocks from strobe
cdc should be kept
now if clock S is fast no problem, strobe X can be synced to domain Sand it meets the
4 X clocks
what if clock S is slow ??
thanks for any help
put the pulse to CK pin of the flop and let this flop toggle whenever the pulse comes. Detect the rise or fall edge from this flop in domain S.
however, if you get more than 2 pulses within a one S clock cycle, you need to rethink about whole system again.
ok, still suppose timer S runs at 100 Mhz (10ns)
while clock X runs at 500 M (2ns)
when there is a strobe X, application must get the timer value up to 4 X cycles (8 ns)
thats less than S clock period
so problem seems to be solved by sampling the timer every 10 ns at S domain
but the transfer to domain X is hard (need prevent cdc problems)
how do we know when is the last valid sample just before strobe X etc
seems easy when thinking but dont find the formulation
Clock X is fast enough to perform synchronous edge detection of clock S. The synchronized clock S allows to sample timer S safely at clock domain X. So it's continuously available.
still all solutions submitted are not sufficient
can you write a verilog model for it that has no cross domain clock problems ?
verilog is more easy to understand
The below construct makes a synchronized counter value available in the fast clock domain:
always @(clock_S)
  cnt <= cnt + 1;
always @(clock_X)
begin
  edge_det[1:0] <= {edge_det[0],clock_S};
  if (edge_det == '01')
    cnt_sync <= cnt;
end;
Alternatively, a gray coded count value can be transferred safely without synchronization. That's the usual method to exchange pointers in domain crossing FIFOs and even works, if both clock domains have almost same frequency.
The above seems to assume there will be no metastability on the registers in edge_det. It probably needs extra registers for the counter and the clock_S, so the edge detection can be reliably done, and the counter can be the correct value associated with the delayed clock edge.
I think the gray codes are probably a better choice overall.
Reactions: FvM
    FvM
It probably needs extra registers for the counter and the clock_S, so the edge detection can be reliably done.
Yes, at least for the dege detection. With a 4:1 frequency ratio, the below code still works. If the double registering of clock_S achieved in edge_det[1] doesn't give sufficient metastability margin, I would prefer gray encoding.
  edge_det[2:0] <= {edge_det[1:0],clock_S};
  if (edge_det[2:1] == '01')
