XtremeTuningSolutions
Member level 1
Hello,
I am looking to create a sample and hold design. The design must consists of changing voltage and being able to lock the the voltage in. The voltage control would be changed by a Joystick. The further the Joystick left or right the higher the voltage change. The joystick can then be pushed down to lock the voltage in and should not bleed out. Voltage Range should be 1v to 10.30v
Ex: Push the joystick to the left the meter reads 6 volts. Then push it down which would lock the voltage in at 6v and the joystick would return to the center. Similar to a Play Station 3 controller the R3 button is the push down.
Does anybody know of anything related to this or have something i can work with?
Please let me know.
Thank You
Please let me know.
Thank You
