As far as I understand, in order to simulate post-PAR model, I should compile SIMPRIM library. And to do that, I should choose the simulator I'll be using. And Isim is not in the list.Sure you can. I've been doing far too much post place & route simulation lately. And in Isim (13.1) no less. So what makes you think you can't?
(* ASYNC_REG = TRUE *) reg my_async_stuff = 1'b0; // this will help help simulate your asynchronous logic
My thoughts exactly.So judging by the fact that you get a running simulation I'd say you have the libraries alright.
And then again, it was simulating way too fast. Like 5 times faster than corresponding RTL model does.
yes, I got what you meant the last time. Just not before that.By "simulation running too fast" I meant exactly what I said
Nope...Maybe different settings?
OK, I got it.
It is only now that I have noticed a warning (well, a hundred of warnings):
" <x_xor2> remains a black-box since it has no binding entity.". And similar for other components.
And I think I've found source files for all the primitives.
One thing I really hate about ISE - it's really bad at handling librarys with large amount of files...
Now I have no warnings while compiling and elaborating, and simulation runs slowly (just as I like:-D), but again - nothing on output ports of UUT...
Yep. I initially included some, but not all (really don't understand how could it happen).You needed the ones in "ise_124/ISE_DS/ISE/vhdl/src/simprims/" or something like it?
Clock signal (and some other signals) is generated by testbench, it's simple plain VHDL. It's UUT is post-PAR model, to which testbench feeds input signals (clock included). And outputs of UUT are U's.Nothing, not even a clock signal or something like that?
I'm really stupid today. Now I got it, thanks for the idea.That's what I meant by "now even clock?" since I would expect at least something like that to arrive in one piece to the UUT module...
