Means each antenna length caters to a specific frequency band and not a specific frequency?
Can the same antenna be used for transmission and reception when the transmission and reply frequencies are 63Mhz apart?
Hi.
yes ofcourse but you dont connect an antenna both at the input reciver tuner and RF output of transmitter as same point connection so you must use a " QRP " circuit at your transciver.
although you can use a relay to connect the antenna to transmitter output when you push microphone's Key and disconnect that antenna from reciver's tuner independently.
The QRP is a simple circuit usually used afew of component such as diode and capacitor and Resistor.
If you need some of them PLZ contact me .
angrygtnote@gmail.com
Tehran-Iran
