S8050 with IR Transmitter
hossam abdo
Full Member level 2
Alexandria, Egypt, Egypt
Dear friends
How to use the S8050 transistor with the Ir led transmitter to amplify the signal to higher rage.
thanks in advance,
SunnySkyguy
Advanced Member level 5
Richmond Hill, ON, Canada
what is your battery and Led spec?
The transistor should be used with only a current gain of 10. Higher rated devices will have a lower ESR and drop voltage.
Collector-emitter saturation voltage VCE
(sat) IC
= 500mA, IB
= 50 mA 0.6 V
Base-emitter saturation voltage VBE
(sat) IC
= 500mA, IB
= 50 mA 1.2 V
