Running two versions of MENTOR PADS at the same time
seyyah
Advanced Member level 2
mentor pads vista compatibility
Is it possible to run PADS 2007.2 and 2007.4 at the same time on a single computer? I'm having difficulties converting the old projects to new one. So i want to keep both version and will try to find a solution in time.
running two version of pads
better u try to install in different drives of same computer .
mentor pads on virtual pc
I never tried but it is possible.
If you have run both installation on the same SDD_HOME Directory the configurator file keeps tracks of all the versions. You have to launch it (it shuold be in SDD_ROOT\win32\configurator.exe) and then select the version you want to run.
If you have two SDD_HOME, before you launch one version you have to run the configurator.exe from the other version in unistall mode (from command line: configurator.exe -unistall) and then the configurator from the actual version normally.
mentor pads 2007.2 vista
funnynypd said:
why you need two version. We always try to keep one because it is not so compatible between versions.
Because I'm using vista and could not install 2007.2 at first even with compatibility mode and 2007.4 had problems in translating old projects that i could not solve. Then i could be able to set up 2007.2 somehow. But it has no vista support and i wanted to keep trying to find a solution for 2007.4 while i'm doing my job in 2007.2.
Try installing microsoft virtual pc and install the required OS and the mentor pads version it supports. Switch windows and share the folder.
Hope this helps
Nishal
