Running CORTEX-M0 using 8bit SRAMs
elockpicker
Member level 4
Hi all,
Is it possible to run CORTEX-M0 (which has a 32bit data bus) using an 8bit SRAM ?
If possible, the method would be the following, right?
Method: a memory controller has to be used(built) that operates as a AHB-Lite slave. Furthermore it has to use wait states to read 4 bytes to built a 32bit word.
Tome it seems, it can't be done without using wait states.
Thank you.
