Rules regarding layer stackup
nirajvlsi
Junior Member level 2
Hi all,
I need a help regarding layer stackup. I want to know if there exists any law or rule which is needed in case of deciding on Layer stackup.
It will be of great help !!
Best regards to all
Niraj
senilicus
Full Member level 5
Amsterdam / The Netherlands
Re: Layer Stackup Rule
In general, keep your stackup symmetrical from the middle of the stackup, this will reduce bow and twist.
If possible put a power and ground plane together, this will act as a capacitor.
For stackup dimensions you have to contact the pcb manufacturer, he can tell you wich materials (and thicknesses) are on stock. You also need these numbers for any impedance calculation.
When you finalize you'r stackup contact the pcb manufacturer again and let them
have a look at the stackup. They will give you a gonogo.
muralicrl
Full Member level 5
Bangalore
Hi friend,
you can follow the following rule for 4 layer PCB.
1.signal
2.power
3.ground
4.signal
For more details pl contact me.
Regards,
N.Muralidhara
Raju_epigon
Member level 5
Hai,
Check this one for 6 Layaer Board,
1. Top
2. GND
3. IN1
4. IN2
5. PWR
6 BOT
Added after 39 minutes:
Check this one
jayasuryan
Member level 5
You can define Layer Stackup-as per your requirement by considering following....
1. Signal Integrity
2. EMI Effects
3. Decoupling
Keep in mind the above constraints and define Layer Stackup. If you keep GND-VCC planes close to each other in multi-layer PCBs that generate intrinsic capacitance due to GND-VCC plane. That Intrinsic Capacitance we can utilize...
For best results in 4,6 and 8 Layer you can follow the Layer Stackup
4 Layer PCB
1.SIGNAL
2. GND
3. VCC
4. SIGNAL
6 Layer PCB
1.SIGNAL
2. GND
3. VCC
4. VCC
5. GND
6. SIGNAL
8 Layer PCB
1.SIGNAL
2. GND
3. SIGNAL
4. GND
5. VCC
6. SIGNAL
7. GND
8. SIGNAL
