Sree Harsha M
Newbie level 1
Hello,
I need to model a clock divider clock with the following pins and functionality:
1. input iclk -
This pin is input clock . It can be any one of 10Mhz, 20Mhz, 30, 40....160Mhz.
2. input [3:0] iclk_div_sel
The input given to this pin is dependent on the frequency given to iclk i.e,
if 10Mhz is given on iclk, then iclk_div_sel should be 0000,
if 20Mhz is given on iclk, then iclk_div_sel should be 0001,
if 30Mhz is given on iclk, then iclk_div_sel should be 0010,
if 40Mhz is given on iclk, then iclk_div_sel should be 0011,......AND SO ON.....
if 160Mhz is given on iclk, then iclk_div_sel should be 1111,
3. output oclk
This is output clock. Irrespective of the above mentioned frequencies on iclk...this oclk should be 10 Mhz
Could anyone suggest how to proceed on this? Or is this feasible with this pins or any extra pins are required to achieve this??
Thanks in advance,
-Harsha
1. input iclk -
3. output oclk
Thanks in advance,
-Harsha
