rtc interfacing with 8051
sandeepkjoy
Newbie level 3
CAN ANYONE HELP ME IN INTERFACING RTC DS1307 WITH 8051 MICROCONTROLER:pROGRAM THAT should turn on AN LED WHEN TIME IS 6pm and it turns off led when time is 6am.
check this sir
  • interface ds1307 with 8051.rar
give me a code to turn on led when time is 6pm and to turn it off when time is 6am
i edited the code as your request
// interfacing ds1307 with AT89C51RD2
#include <at89c51xd2.h>
void _nop_(void);
#define delay_us _nop_(); //generates 1 microsecond
#define LCD P1
sbit RS=P3^0; //connect p3.0 to rs pin of lcd
sbit EN=P3^2; //connect p3.2 to en pin of lcd
sbit RW=P3^1; //connect p3.1 to en pin of lcd
sbit SCK=P2^4; //serial clock pin
sbit SDA=P2^5; //serial data pin
sbit led=P2^3; //led
#define SCKHIGH  SCK=1;
#define SCKLOW   SCK=0;
#define SDAHIGH  SDA=1;
#define SDALOW   SDA=0;
void integer_lcd(int);
void init_lcd(void);
void cmd_lcd(unsigned char);
void write_lcd(unsigned char);
void display_lcd(unsigned char *);
void delay_ms(unsigned int);
void start(void);
void stop(void);
void send_byte(unsigned char);
unsigned char receive_byte(unsigned char);
void write_i2c(unsigned char,unsigned char,unsigned char);
unsigned char read_i2c(unsigned char,unsigned char);
//clock[]={seconds,minutes,hours,day_of_week,date,month,year};
unsigned char clock[]={0x00,0x40,0x17,0x06,0x24,0x03,0x06};
unsigned char *s[]={"SUN","MON","TUE","WED","THU","FRI","SAT"};
unsigned char slave_ack,add=0,c,m,k;
unsigned int num;
            // Real Time Clock Mode
void main(void)
init_lcd();
//cmd_lcd(0x01);
//display_lcd("UTL");
//delay_ms(1000);
            while(add<=6)   //update real time clock
                        write_i2c(0xd0,add,clock[add]);
                        add++;
            //          stop();
            while(1)
                c=read_i2c(0xd0,0x02);//read hours register and display on LCD
                        write_lcd((c/16)+48);
                        write_lcd((c%16)+48);
                        write_lcd(':');
                        m=read_i2c(0xd0,0x01);//read minutes register and display on LCD
                        write_lcd((m/16)+48);
                        write_lcd((m%16)+48);
                        write_lcd(':');
						if((c/16)==1 && (c%16)==8 && (m/16)==0 && (m%16)==0)//6:00 pm
							led=0; //turn on led
						else if((c/16)==0 && (c%16)==6 && (m/16)==0 && (m%16)==0)//6:00 am
							led=1; //turn off led
                        delay_ms(10);
                        c=read_i2c(0xd0,0x00);//read seconds register and display on LCD
                        write_lcd(' ');
                        display_lcd(s[read_i2c(0xd0,0x03)]);//read day register and display
                        cmd_lcd(0xc0);
                        c=read_i2c(0xd0,0x04);//read date register and display on LCD
                        write_lcd('/');
                        c=read_i2c(0xd0,0x05);//read month register and display on LCD
                        write_lcd('/');
                        write_lcd('2');
                        write_lcd('0');
                        c=read_i2c(0xd0,0x06);//read year register and display on LCD
                        delay_ms(100);
                        cmd_lcd(0x01);
//starts i2c, if both SCK & SDA are idle
void start(void)
            if(SCK==0) //check SCK. if SCK busy, return else SCK idle
                        return;
            if(SDA==0) //check SDA. if SDA busy, return else SDA idle
                        return;
SDALOW //data low
delay_us
SCKLOW  //clock low
delay_us
//stops i2c, releasing the bus
void stop(void)
SDALOW //data low
SCKHIGH //clock high
delay_us
SDAHIGH //data high
delay_us
//transmits one byte of data to i2c bus
void send_byte(unsigned char c)
unsigned mask=0x80;
            do  //transmits 8 bits
                        if(c&mask) //set data line accordingly(0 or 1)
                                    SDAHIGH //data high
                        else
                                    SDALOW //data low
                        delay_us
                        SCKLOW   //clock low
                        delay_us
                        mask/=2;  //shift mask
            }while(mask>0);
SDAHIGH  //release data line for acknowledge
SCKHIGH  //send clock for acknowledge
delay_us
slave_ack=SDA; //read data pin for acknowledge
SCKLOW  //clock low
delay_us
//receives one byte of data from i2c bus
unsigned char receive_byte(unsigned char master_ack)
unsigned char c=0,mask=0x80;
            do  //receive 8 bits
                        delay_us
                                    if(SDA==1) //read data
                                                c|=mask;  //store data
                        SCKLOW  //clock low
                        delay_us
            }while(mask>0);
            if(master_ack==1)
                        SDAHIGH //don't acknowledge
            else
                        SDALOW //acknowledge
delay_us
SCKLOW //clock low
delay_us
SDAHIGH //data high
return c;
//writes one byte of data(c) to slave device(device_id) at given address(location)
void write_i2c(unsigned char device_id,unsigned char location,unsigned char c)
            do
                        start();      //starts i2c bus
                        send_byte(device_id); //select slave device
                        if(slave_ack==1)  //if acknowledge not received, stop i2c bus
                                    stop();
            }while(slave_ack==1); //loop until acknowledge is received
send_byte(location); //send address location
send_byte(c); //send data to i2c bus
stop(); //stop i2c bus
delay_ms(4);
//reads one byte of data(c) from slave device(device_id) at given address(location)
unsigned char read_i2c(unsigned char device_id,unsigned char location)
unsigned char c;
            do
                                    stop();
send_byte(device_id+1); //select slave device in read mode
c=receive_byte(1); //receive data from i2c bus
return c;
/*display of 16bit(integers) values on LCD
void integer_lcd(int n)
unsigned char c[6];
unsigned int i=0;
  if(n<0)
    write_lcd('-');
    n=-n;
  if(n==0)
    write_lcd('0');
  while(n>0)//Split integer to 2 bytes and send on 8bit line.
    c[i++]=(n%10)+48;
    n/=10;
  while(i-->=1)
    write_lcd(c[i]);
//initialize lcd
void init_lcd(void)
delay_ms(10); //delay 10 milliseconds
cmd_lcd(0x0e); //lcd on, cursor on
delay_ms(10);
cmd_lcd(0x38); //8 bit initialize, 5x7 character font, 16x2 display
delay_ms(10);
cmd_lcd(0x06); //right shift cursor automatically after each character is displayed
delay_ms(10);
cmd_lcd(0x01); //clear lcd
delay_ms(10);
cmd_lcd (0x80);
//transmit command or instruction to lcd
void cmd_lcd(unsigned char c)
EN=1;
RW=0;//set enable pin
RS=0; //clear register select pin
LCD=c; //load 8 bit data
EN=0; //clear enable pin
delay_ms(2); //delay 2 milliseconds
//transmit a character to be displayed on lcd
void write_lcd(unsigned char c)
EN=1; //set enable pin
RW=0;
RS=1; //set register select pin
//transmit a string to be displayed on lcd
void display_lcd(unsigned char *s)
while(*s)
write_lcd(*s++);
//generates delay in milli seconds
void delay_ms(unsigned int i)
unsigned int j;
            while(i-->0)
                        for(j=0;j<500;j++)
i also attached the project file and proteus simulation file.
