rtc DS1307 problem on mikroC pic compiler
Noman Yousaf
Full Member level 4
Lahore Pakistan
hi
i am using RTC DS1307 with pic16f887.
using very common code for mikro c, avilable on net.
problem is
when i run the code on debugger, "read_time" routine sticks on "I2C1_start();"
can anybody help?
code is:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
// LCD module connections
sbit LCD_RS at RB3_bit;
sbit LCD_EN at RB2_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB3_bit;
sbit LCD_EN_Direction at TRISB2_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
// End LCD module connections
char txt1[] = "mikroElektronika";
char txt2[] = "EasyPIC6";
char txt3[] = "Lcd4bit";
char txt4[] = "example";
char i;
// Loop variable
unsigned char sec, min1, hr, week_day, day, mn, year;
char *txt, tnum[4];
void Zero_Fill(char *value) { // fill text repesentation
if (value[1] == 0) { // with leading zero
value[1] = value[0];
value[0] = 48;
value[2] = 0;
void Read_Time(char *sec, char *min, char *hr, char *week_day, char *day, char *mn, char *year) {
I2C1_Start();
I2C1_Wr(0xD0);
I2C1_Wr(0);
I2C1_Repeated_Start();
I2C1_Wr(0xD1);
*sec =I2C1_Rd(1);
*min =I2C1_Rd(1);
*hr =I2C1_Rd(1);
*week_day =I2C1_Rd(1);
*day =I2C1_Rd(1);
*mn =I2C1_Rd(1);
*year =I2C1_Rd(0);
I2C1_Stop();
//-------------------- Formats date and time
void Transform_Time(char *sec, char *min, char *hr, char *week_day, char *day, char *mn, char *year) {
*sec = ((*sec & 0x70) >> 4)*10 + (*sec & 0x0F);
*min = ((*min & 0xF0) >> 4)*10 + (*min & 0x0F);
*hr = ((*hr & 0x30) >> 4)*10 + (*hr & 0x0F);
*week_day =(*week_day & 0x07);
*day = ((*day & 0xF0) >> 4)*10 + (*day & 0x0F);
*mn = ((*mn & 0x10) >> 4)*10 + (*mn & 0x0F);
*year = ((*year & 0xF0)>>4)*10+(*year & 0x0F);
//-------------------- Output values to LCD
void Display_Time(char sec, char min, char hr, char week_day, char day, char mn, char year) {
switch(week_day){
case 1: txt="Sun"; break;
case 2: txt="Mon"; break;
case 3: txt="Tue"; break;
case 4: txt="Wed"; break;
case 5: txt="Thu"; break;
case 6: txt="Fri"; break;
case 7: txt="Sat"; break;
Lcd_Init();
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1,1,txt);
Lcd_Chr(1, 6, (day / 10) + 48); // Print tens digit of day variable
Lcd_Chr(1, 7, (day % 10) + 48); // Print oness digit of day variable
Lcd_Chr(1, 9, (mn / 10) + 48);
Lcd_Chr(1,10, (mn % 10) + 48);
Lcd_Chr(1,15, year + 48); // Print year vaiable + 8 (start from year 2008)
Lcd_Chr(2, 6, (hr / 10) + 48);
Lcd_Chr(2, 7, (hr % 10) + 48);
Lcd_Chr(2, 9, (min / 10) + 48);
Lcd_Chr(2,10, (min % 10) + 48);
Lcd_Chr(2,12, (sec / 10) + 48);
Lcd_Chr(2,13, (sec % 10) + 48);
void Init_Main() {
// ADCON1 = 0x0F; // page 268
// ANSEL=0;
// ANSELH=0;
trisc =0;
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear LCD display
Lcd_Cmd(_LCD_CURSOR_OFF); // Turn cursor off
I2C1_Init(100000); // initialize I2C
Lcd_Chr(1,8,'.');
Lcd_Chr(1,11,'.');
txt = "Time:";
Lcd_Out(2,1,txt);
Lcd_Chr(2,8,':');
Lcd_Chr(2,11,':');
txt = "201";
Lcd_Out(1,12,txt);
void main() {
Init_Main();
// Read_Time(&sec,&min1,&hr,&week_day,&day,&mn,&year); // read time from RTC(DS1307)
// Transform_Time(&sec,&min1,&hr,&week_day,&day,&mn,&year); // format date and time
// Display_Time(sec, min1, hr, week_day, day, mn, year); // prepare and display on LCD
// Delay_ms(1000);
while (1) {
Delay_ms(1000); // wait 1s
i did it
actually i missed pull-up resistors on SDA and SCL in protues so it was happening.
Also make sure that the resistor you are using in proteus is of digital type.
I had faced issue with this also.
