Vijetha H.N
We use a Panasonic Lithium coin cell (3V, part #BR2330) for RTC chip DS1307, in the design of a handheld device and its a mass production. Now in some of the boards 2 different issue are found. Please drop your comments/suggestions on the issue.
1. The RTC battery is connected to an 8 layer PCB as through hole. After assembly, the continuity between the PCB Ground point and the Ground point for RTC battery is lost. Now i removed RTC battery, still there is no continuity between the GND point of PCB and ther GND hole for RTC battery.
If I apply pressure into the hole of GND for RTC battery; i.e if i tightly mount or insert any object into that hole for RTC battery GND, the continuity is regained. If the inserted object is removed; i.e if the pressure is released again no continuity. The GND layer comes as 3rd layer. I feel dude to excessive temperature, the copper wall of the GND hole for RTC got deformed internally and hence got disconnected from the 3rd GND layer. Can there be any other possibilities?
There is another different but related issue.
2. A board was kept under ESD protection in a box for 1 month. After 1 month the battery got drained to 0.2-0.5V.
Actually RTC battery in addition to supplying to RTC chip; is also used as back up to GPS module (LEA6H) to minimize time to first fix. RTC chip take s a current of around 500nA and the GPS module takes around 0.024mA (only when GPS application is not active). Battery capacity is 255mAh. So atleast it must supply for minimum 1 year. What can be the reason for the sudden draining of battery then?
After replacing the battery its working fine.
Plz give your comments on these.
Thank You and regards,
Vijethahn
Let me know if any of the points mentioned above is not clear to the reader.
Vijethahn
