scintrillating
Newbie level 3
I have Interfaced 12C887 with P89V51RD2 but the time update does not occur. However the same code when burned in AT89C51, works perfectly...But due to memory restrictions of 4Kb in the Later, we have to use the former. Please help me out on this issue, ASAP!
The Code is :
The Code is :
#include <P89V51Rx2.H>
#include<ABSACC.h>
#define port P3
#define lcd_dataport P2 // lcd_dataport for lcd
#define keypad P1 // Port for keypadpad
#define timeport P0 // Port for RTC
sbit rs = port^0;
sbit rw = port^1;
sbit en = port^5;
int hr, min, sec;
void delay(unsigned int msec) //Time delay function
int i,j ;
for(i=0;i<msec;i++)
for(j=0;j<1275;j++);
void lcdcmd(unsigned char item) //Function to send command to LCD
lcd_dataport = item;
rs=0;
rw=0;
en=1;
delay(1);
en=0;
return;
void lcddata(unsigned char item) //Funtion to send data on LCD
rs=1;
rw=0;
en=1;
delay(1);
en=0;
void lcddata_string(unsigned char *str) // Function to send string on LCD
int i=0;
while(str[i]!='\0')
lcddata(str[i]);
i++;
delay(1);
void lcd(unsigned char str[10]) // Funtion display string on LCD
lcdcmd(0x38);
lcdcmd(0x0C);
lcdcmd(0x01);
lcdcmd(0x80);
lcddata_string(str);
void rtc_read(unsigned char item)
timeport = item;
void rtc_write(unsigned char item)
timeport = item;
void bcdconv(unsigned char mybyte)
unsigned char x,y;
x=mybyte&0x0F;
x=x|0x30;
y=mybyte&0xF0;
y=y>>4;
y=y|0x30;
lcddata(y);
lcddata(x);
void main()
delay(220);
XBYTE[11]=0x82;
XBYTE[4]=0x15;
XBYTE[2]=0x55;
XBYTE[0]=0x00;
XBYTE[11]=0x02;
lcd("TIME:");
while(1)
lcdcmd(0x88);
rtc_read(0x00);
