Register Log in
RS485, automatic driver disable/enable signal generation
buenos
Advanced Member level 3
Sunnyvale, California, USA
uart st16c550 rs485
hi
for RS485 half duplex or multidrop systems, we have to disable the TX driver when we are not transmitting. Normally it is done by the DTR or RTS signal from the UART, controlling the buffer within the transceiver.
Is there a way to generate this automatically by the UART without any software intervention? is it in the standard PC 16550 UART?
FvM
Super Moderator
Staff member
Bochum, Germany
rs485 automatic driver enable
Some recent UARTs have an option to generate RS485 TE automatically, e.g. EXAR ST16C650, but standard 16550 doesn't. The common solution is a a timer, that enables the transmitter for defined period after a TX bit. There are basically two options:
- Using a long TE intervall (> 1 character frame). Involves a risk of collisions, if the peer responds too fast.
- A short TE intervall, just sufficient to drive the cable capacitance to the opposite level. Operation depends on meaningful dimensioned bias resistors in the termination network and isn't realiable for long cables.
An exact, frame accurate transmitter control can be achieved from an UART generated TE signal (as with said ST16C550), with a driver software generated TE (at least at low and medium speed) and by an external hardware, that is decoding the protocol (as with some RS485 repeaters).
buenos
rs485 without enable
hi
thanx.
actually I found a nice solution on the internet:
-dont disable RX during transmit operation
-enable/disable transmit by GPIO (RTS pin on superio)
-send a termination caracter as a last one in every transaction.
-enable tx before transmit starts, disable in RX-interrupt routine when termination character was received back. so not in a TX complete irq routine beceuse it is unaccurate.
-during TX mode, throw away all received data in RX-interrupt routine.
