RS-422 D-Sub 9 pin Male Pinout
jimmykk
Full Member level 3
Hi I am trying to figure out what could be the possible pinouts for the rest of the pins on a D-Sub 9 Pin Male Connector.
I have only 5 pins necessary for RS-422 Communication as shown here:
But can't figure out the rest of the 4 pins(1,4,6 and 9) should go namely: CTS+, CTS-, RTS+ and RTS-.
I understand that i am free to choose pinout for these remaining pins as there is no standard set-up for them.
But would be nice to know if this type of pinout is kind of ''popular'' and i can just then follow
that pinout.
Thanks!
Without knowing what this connector is part of, it’s impossible to answer your question.
But there’s no reason to believe there’s CTS+/- etc. What makes you think there is?
There’s no standard for RS-422 on a DB-9 (that I’m aware of).
Are you serious??
You arbitrarily connected some wires to arbitrary pins on an arbitrarily selected connector, based on some diagram you found somewhere that has nothing to do with the device, and now you’re asking where to connect the rest of the wires?
What are you trying to achieve? If connecting to a specific device with RS-422 interface, does it use RTS/CTS handshake lines at all? Probably not.
LaTeX Commands Quick-Menu:
