RS-232 serial communication
dayal
Member level 3
Hi ,
I would like to know about Interfacing 8051 microcontroller into PC via RS-232 connector, can anyone tell me how i can do it,
what are the steps i can take ..
you can use RS232 Driver chips..."MAX232 - MAX233...."
read the datasheets and you will understand everything
after reading ask your questions heare :)
In the down load software section there is an RS232 communication software use max232 as an interface with the 8051 core.For connecting the H/W u can refer the data sheet or u can go through mazid and mazid book or ayala book pls let me know if u have any problem
use mscomm control in vb send ascii coded signals from your controller via 8051 serial port this is the right and easy way to go
  • uctrainerkit_3281.pdf
