abionnnn
Member level 1
event counter +avr
I've got a big task to complete by a month when my thesis is due. I need a bit of advice, so that this doesn't take longer than neccesary.
I've got two inputs, a frequency standard 5MHz sine signal which I'm going to use as a time stamp by sending it to a counter/divider IC. This signal would then have to go to a microcontroller which can be polled via RS-232 which then would send a binary string of a counter representing the time in milliseconds.
At the same time that this is happening, a rotating table with LEDs fitted on which would send pulses at a non-periodic rate. I need to input capture these pulses and increment a counter which would represent the table's position. We've set up one of the pulses to be a doublet which would kind of be a failsafe incase we miss a point. When a computer polls the microprocessor for the time, we would also like to send a string representing the position of the table.
Obviously, we're going to need a fast microcontroller to handle things like this reliably. Can anyone suggest a microcontroller that is up to it? More importantly, a ready made board with it on it which can be delivered to Australia within a week or so?
Thank you all for your time.
