cocopa
Junior Member level 2
Hello! I've read in many books that we should not be routing nets over split planes because the return currents will have no path to return. Split planes refer only to the ground plane that the signal is referenced to?Or we should avoid routing over splits in power planes too? And finally about LVDS signals, since each pair has its return path in the adjacent line, do i have to worry about split planes? Thank you.
