cimon
Newbie level 1
benchmark formats
hello I am very confused and have question about routing benchmark formats like LEF/DEF format, labyrinth format etc.
what is the difference between these above mentioned formats and Interchange Format. Why Interchange format like BLIF( Berkley logic interchange format) has the word "interchange"....does that mean one format can be changed to other.
A book definition of interchange format states that "interchange format" is file or set of files that contain data in a given syntax that is understood by interacting tools .
what it means by interacting tools....I thought it should be "..........given syntax that is understood by routing/placement tools"
And is that true that particular routing tools understand some particular format.
Thank you thank you
Thank you thank you
