dw_man
Junior Member level 3
- Joined
- Aug 7, 2013
- Messages
- 26
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 188
Routing problem using Classic route and Zroute
I have a small design which includes a macro RAM block and am trying to perform the Place and Route in IC Compiler. Is there any particular guidelines that I need to follow. I create a floorplan and then fix the RAM macro which seems to be required before doing the placement.
When I perform routing using route_zrt, I am getting DRC violations relating to Over max stack level referring to vias. These seem to be coming from the I/O of the macro. How can I rectify this, or what is specifically causing this problem. Is there a setting or a command that I need to perform to avoid this?
When I route the design using the classic router and switching off the features of the ZRouter, I do not receive any DRC violations. Why are they providing me with different results. I'm using Faraday 90nm if that makes any difference to the results.
Thanks.
Thanks.
