Router delay simulator
Delared
Junior Member level 1
Hi All,
I have a number of devices which communicate to each others through analog signals.
what I'm looking for is a mediator device bywhich I can interface my devices as shown in the attached fig.
To be clear, with the desired controller I should be able to do:
- routing received signal from one device to another
- delaying some signals in specific instance
- using a software interface to perform the desired specifcation.
- I need at least 10 analog inputs and 3 analog outputs.
my questions:
- what's the good device for my application
- how can I use it, if there are some docs to facilite my application
Regards,
A specification of signal characteristics (bandwidth, maximum voltage and dynamic range, source and load impedances) and intended delay range would be required.
It also won't hurt to tell quite a bit about the instrument's purpose.
FvM,
-The analog signal input frequency is about 24KHz
- the delay range is about 0 to 25µsec
- voltage range is +/- 10V for analog inputs and +-5V for the outputs
