Hello - I am trying to create a counter that will increment and decrement based on the direction the switch is turned. The counter is easy, but how do I read the input?
process(clk)
begin
if rising_edge(clk) then
--Increment
if switch = '1' then
counter <= counter + 1;
else
counter <= counter - 1;
end if;
end if;
end process;
process(clk)
begin
--Increment
else
end if;
end if;
end process;
That sort of makes sense. The switch isn't part of the FPGA, so I need to assign an input (button or switch) that is on the board, to an input on the FPGA?
This is what I'm trying to do:
A synchronous up/down counter in VHDL that:
-Counts from 0 to FFFF.
-Uses the rotary switch to increment (rotate right) and decrement counter (rotate left).
-2 Push Buttons (pick any 2 of 4 available): one for an asynchronous reset (starts @ 0) & an a “synchronous” (hold button & rotate left or right) preset (starts @ BEEF). Need to de-bounce these switches in software.
-Write the count value to an LCD
So far, I have a counter
I respect and hate this stuff all at the same time :O
Yes. If you have a development board, the switches will already be connected to FPGA pins. You just need to map a top level input in your code to that pin on the FPGA.
