Nov 6, 2012 #1 V vamsee Full Member level 1 Joined Nov 6, 2012 Messages 95 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,288 Activity points 1,885 Hi!! i want to know whether there is rotary encoder which can fixed to 30cm diameter shaft.. Thank you
Nov 6, 2012 #2 K KMoffett Full Member level 5 Joined Feb 11, 2008 Messages 297 Helped 43 Reputation 86 Reaction score 22 Trophy points 1,298 Location Minnesota USA Activity points 2,771 Incremental?...absolute?...environment?...speed?...hollow shaft? Ken
Nov 11, 2012 #3 E elecfan Member level 1 Joined Nov 8, 2012 Messages 34 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Location Earth Activity points 1,571 May ask how the diameter is affecting the encoder? as far I know, the encoder can be attached to the shaft with any diameter!
Nov 11, 2012 #4 H HTA Advanced Member level 1 Joined Nov 17, 2011 Messages 445 Helped 108 Reputation 216 Reaction score 104 Trophy points 1,323 Activity points 3,925 30cm shaft is quite special and normal encoder will support only a few cm. There are however bearingless encoder for shafts up 70cm and more, like this one here: **broken link removed** . Enjoy your design work!
