ROM and RAM connection
Kosyas41
Member level 3
Hello,
Im write top level entity for ROM and RAM blocks,I want to connect ROM block with RAM.In ROM block data_a_i and data_b_q I want to connect with data_a and data_b in RAM block.But I faced with error/Could you pls help me to solve this problem
library ieee;
     use ieee.std_logic_1164.all;
     use ieee.std_logic_unsigned.all;
    use ieee.numeric_std.all ;
    use ieee.math_real.all ;
    use ieee.math_complex.all ;
entity ROMRAM is
    port (
        CLOC: IN std_logic;
        ADD: IN integer range 0 to 511;
        DATA_WIDTHi : integer := 256;
        ADDR_WIDTHi : integer := 256;
        clk    : in  std_logic;
        we_ai   : in  std_logic;
        addr_ai : in  std_logic_vector(ADDR_WIDTHi-1 downto 0);
        q_ai   : out std_logic_vector(DATA_WIDTHi-1 downto 0);
        we_bq   : in  std_logic;
        addr_bq : in  std_logic_vector(ADDR_WIDTHi-1 downto 0);
        q_bq    : out std_logic_vector(DATA_WIDTHi-1 downto 0));
end ROMRAM;
architecture rtl of ROMRAM is
--- Component decalarartion
Component sync_rom is
    port(
        clock: IN std_logic;
        address: IN integer range 0 to 511;
        data_a_i: OUT integer range 0 to 255;
       data_b_q: OUT integer range 0 to 255
end component;
Component dp_ram_rbw_scl is
generic (
        DATA_WIDTH : integer := 256;
        ADDR_WIDTH : integer := 256
    port(
        clk    : in  std_logic;
        we_a   : in  std_logic;
        addr_a : in  std_logic_vector(ADDR_WIDTH-1 downto 0) ;
        data_a : in  std_logic_vector(DATA_WIDTH-1 downto 0) ;
        q_a    : out std_logic_vector(DATA_WIDTH-1 downto 0);
        we_b   : in  std_logic;
        addr_b : in  std_logic_vector(ADDR_WIDTH-1 downto 0) ;
        data_b : in  std_logic_vector(DATA_WIDTH-1 downto 0) ;
        q_b    : out std_logic_vector(DATA_WIDTH-1 downto 0)
end component;
for all : sync_rom use entity work.sync_rom(rtl);
for all : dp_ram_rbw_scl use entity work.dp_ram_rbw_scl(rtl);
Signal     data_a_i: integer range 0 to 255;--interanal signals
Signal     data_b_q: integer range 0 to 255;--interanal signals
begin
-- Component Instantiation
C1: sync_rom Port map (
                                clock => CLOC,
                                address =>ADD,
                                data_a_i =>data_a_i,
                                data_b_q =>data_b_q
C2: dp_ram_rbw_scl Port map (
                                    clk=>CLOC,
                                    we_a=>we_ai,
                                    addr_a=>addr_ai,
                                    data_a =>data_a_i,
                                    q_a=>q_ai,
                                    we_b=>we_bq,
                                    addr_b=>addr_bq,
                                    data_b =>data_b_q,
                                    q_b=>q_bq
                                data_a<=to_integer(data_a_i);
                                data_b_q<=to_integer(unsigned(data_b));
end rtl;
but i have error
Error (10476): VHDL error at Vhdl2.vhd(67): type of identifier "data_a_i" does not agree with its usage as "std_logic_vector" type
This is the error.
Is it possible to convert it?or I should change the type of data?
Im solved this problem with conversion
library ieee;
entity ROMRAM is
generic(
		  DATA_WIDTHi : integer := 8;
        ADDR_WIDTHi : integer := 8);
    port (
        CLOC: IN std_logic;
		  data_a : in std_logic_vector(DATA_WIDTHi-1 downto 0);
		  data_b : in std_logic_vector(DATA_WIDTHi-1 downto 0);
        data_a_i : in integer range 0 to 255;
		  data_b_q : in integer range 0 to 255;
        --clk    : in  std_logic;
end ROMRAM;
    port(
end component;
generic (
        DATA_WIDTH : integer := 8;
        ADDR_WIDTH : integer := 8
    port(
        clk    : in  std_logic;
end component;
Signal     data_a_i_i: integer range 0 to 255;--interanal signals
Signal     data_b_q_i: integer range 0 to 255;--interanal signals
begin
                                clock => CLOC,
                                address =>ADD,
                                data_a_i =>data_a_i_i,
                                data_b_q =>data_b_q_i
C2: dp_ram_rbw_scl
Port map (
                                    clk=>CLOC,
                                    we_a=>we_ai,
                                    addr_a=>addr_ai,
                                    data_a =>data_a,
                                    q_a=>q_ai,
                                    we_b=>we_bq,
                                    addr_b=>addr_bq,
                                    data_b =>data_b,
                                    q_b=>q_bq
											data_a_i_i<= to_integer(unsigned(data_a));
											data_b_q_i<= to_integer(unsigned(data_b));
											data_a_i_i<= data_a;
end rtl;
but now,when I open RTL viewer/I didt see connection between data_a and data_a_i
data_b and data_b_q
Is it correct code?
Chk your port map code area.
Use the same signal name for port mapping.
Yes I checked/whats wrong?Could you pls give me some hint
The data_a pins of the ROM are outputs, but you are assigning them with the following code:
Code VHDL - [expand]
data_a_i_i<= data_a; -- why are you assigning this again?
You will need to convert the other direction from integer to std_logic_vector:
the_slv <= std_logic_vector(to_unsigned(the_int, the_slv'length));
Thanks,as you said before I should do like this?
C2: dp_ram_rbw_scl
Port map (
                                    clk=>CLOC,
                                    we_a=>we_ai,
                                    addr_a=>addr_ai,
                                    data_a =>data_a,
                                    q_a=>q_ai,
                                    we_b=>we_bq,
                                    addr_b=>addr_bq,
                                    data_b =>data_b,
                                    q_b=>q_bq
											data_a_i_i <= std_logic_vector(to_unsigned(data_a,data_a_i_i'length));
No, Outputs must not be on the Left Hand Side (LHS) of a assignment.
data_a_i_i is an output of the ROM
8
9
10
11
12
13
14
15
    port(
end component;
                                clock => CLOC,
                                address =>ADD,
                                data_a_i =>data_a_i_i,  -- this is an output DO NOT assign anything to this signal
It would actually make more sense to use unsigned as the type for data_a_i and data_b_q and perhaps even for address. As you already included the numeric_std library it would then only require a cast to change the type between the two component instances.
Ok, I want to connect data_a and data_a_i
data_b and data_b_q,
and data_a_i_i is like an internal signal.Am I right?
I little bit confused how should I assigned connection between those ports
Im trying to follow this instructions
  • VHDL_Hierarchy_Notes.pdf
You would have saved yourself a bunch of headaches if you had just used the exact same port types on both components instead of mixing two different types.
But as that is what you have....
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
--From integer to slv:
component blah
integer_output : out integer range 0 to 255;
component blah_blah
slv_input : in std_logic_vector (7 downto 0);
-- component interconnection signals
signal slv_sig : std_logic_vector(7 downto 0);
signal int_sig : integer range 0 to 255;
--port map of blah
integer_output => int_sig, -- int_sig is driven by the blah component
--port map of blah_blah
slv_input => slv_sig,
-- convert integer to slv
slv_sig <= std_logic_vector(to_unsigned(int_sig, slv_sig'length));
