Ring Laser Gyros (RLG)
sunnywon
Banned
shanghai
Main article: Ring laser gyro
A ring laser gyro splits a beam of laser light into two beams in opposite directions through narrow tunnels in a closed optical circular path around the perimeter of a triangular block of temperature-stable Cervit glass with reflecting mirrors placed in each corner. When the gyro is rotating at some angular rate, the distance traveled by each beam becomes different—the shorter path being opposite to the rotation. The phase-shift between the two beams can be measured by an interferometer, and is proportional to the rate of rotation (Sagnac effect).
In practice, at low rotation rates the output frequency can drop to zero after the result of backscattering causing the beams to synchronise and lock together. This is known as a lock-in, or laser-lock. The result is that there is no change in the interference pattern, and therefore no measurement change.
To unlock the counter-rotating light beams, laser gyros either have independent light paths for the two directions (usually in fiber optic gyros), or the laser gyro is mounted on a piezo-electric dither motor that rapidly vibrates the laser ring back and forth about its input axis through the lock-in region to decouple the light waves.
The shaker is the most accurate, because both light beams use exactly the same path. Thus laser gyros retain moving parts, but they do not move as far.
http://www.fogphotonics.com/Pros_View.aspx?classId=104&id=269
