RGB led driver controllable via 8-bit parallel port
estratos
Junior Member level 2
rgb led parallel port
Hi all,
Does anyone know of a RGB LED driver that could be controlled via a 8-bit parallel port? The idea is to control this driver from a DS2408 1-Wire slave. The DS2408 is an addressable 8-I/O device.
I've searched the network but all drivers I found are controlled via PWM or serial line.
Thanks for your help,
Daniel.
