[SOLVED] RFID using ARM7 LPC2148
djc
Advanced Member level 1
India
Hi all,
I am trying to read the RFID tag value using ARM7 LPC2148. It's simple 12 digit hex code"04003C317871". It is showing perfect when i connect thr RFID reader directly to computer on hyperterminal. However when i read it using said controller it is showing some garbage value. I tested the UART port by sending and receiving the charecters using controller, it's working fine. I tried to display tag no. on LCD also, but not working. Do i nedd to add some code to TAG no. while reading by controller or anything else. Please guide.
Thanx in advance
what type/model of RFID you are using? Couple of question come to the mind. Are you reading the "ID" using its generic software supplied with RFID? If "yes" then it will be definitely using a protocol/encryption technique. Also check about parity bits and the baud rate?
The Reader is EM-18. I havent been given any software with RFID reader. I have simple assive tag whose ID is mentioned above. I just configured the UART registers for UART1 and 0 for ARM7 LPC2148. Receiving RFID input on UART1. I am using 9600 baud rate to send and receive characters on UART0 which is working fine. I havent been given any generic software with RFID. I dont know where I am goin wrong.
Thank you
I have never used such module but after googling i found a helpful link "http://www.engineersgarage.com/embedded/pic-microcontroller-projects/rfid-interfacing-circuit-code".
It uses a pic microcontroller. If this does not solve your problem paste your code here and let the members here see where you are going wrong?
Here is the code
#include <LPC21xx.H>
 unsigned char card_id[12];
 void delay(unsigned long b){
  while (--b!=0);
void init_serial(void)
  PINSEL0       = 0x00050005;   	/* Enabling RxD0 and TxD0, RxD1 and TxD1 */
  U0LCR         = 0x00000083;    	/* 8 bits, no Parity, 1 Stop bit * for UART0*/
  U0DLL         = 0XC3;
  U0FCR			= 0x81;             /*Enable the FIFO registers*/
  U0DLM 		= 0X00;
  U0LCR         = 0x00000003;       /* DLAB = 0  for UART0*/
  U1LCR         = 0x00000083;       /* 8 bits, no Parity, 1 Stop bit for UART1*/
  U1DLL         = 0XC3;
  U1LCR         = 0x00000003;       /* DLAB = 0 * for UART1*/
  U1FCR			= 0x81;          	/*Enable the FIFO registers*/
int receive(void)						/*function for receiving data from sensor (reads byte by byte & returns value if exist)       */
 	unsigned char k;
	//while (!(U1LSR & 0x01))
	//if(U1RBR==0x0a)
	for(k=0;k<=11;k++)
		while (!(U1LSR & 0x01));   /* If U0LSR 1st bit contains valid data, then return value of U1RBR*/
     	card_id[k] =U1RBR;
     	U1LSR = U1LSR & 0x00;
	  return (0);
 void write_command(int cmd) {
  IO1CLR  |= 0x00f00000;                 	/* Clear D4-D7  */
  IO1CLR  |= 0x00040000;	                /* Read/Write = 0 				*/
  IO1CLR  |= 0X00020000;                    /* Register Select = 0,Command */
  IO1SET  |= 0x00f00000 & cmd;  		    /* Set D4-D7    */
  IO1SET  |= 0X00080000;	                /* Enable = 1 					*/
  delay(30000);
  IO1CLR  |= 0x00080000;                	 /* set E to low 	  			*/
void write_data(int dat) {
  IO1SET  |= 0X00020000;    				/* Register Select = 1,Data */
  IO1SET  |= 0x00f00000 & dat;  			/* Set D4-D7    */
  delay(30000);          					//delay ~2ms
  IO1CLR  |= 0x00080000; 					/* Set E to low 		  	*/
void lcd_data(char dat){
  write_data(dat << 16);
  write_data(dat << 20);
void lcd_command(char cmd){
  write_command(cmd << 16);
  write_command(cmd << 20);
void printlcd(unsigned char *CPtr){
  while(*CPtr != '\0') {
	lcd_data(*CPtr);
    CPtr++;
	delay(20000);
void init_lcd(void) {
  IO1DIR 	|= 0x00FE0000;
  delay(200000) ;
  write_command(0x30 << 16);
  delay(100000);
  delay(100000);
  delay(100000);
  write_command(0x20 << 16);
  lcd_command(0x01);	                         /* clear display */
  lcd_command(0x06);	                         /* auto address inc */
  lcd_command(0x0c);	                         /* cursor off */
  lcd_command(0x80);	                         /* first location */
 main(void)
	unsigned int i;
	init_lcd();
	init_serial();
	while(1)
		receive();
		for(i=0;i<=11;i++)
			printlcd(card_id);
			delay(20);
HI,
As suggested by you, i checked out the PIC n RFID interfacing post. The same logic is applied there. I tried to connect pin 7 of RFID to pin 3 of max of controller but not working I think problem is max232 is there too on the RFID reader module. When i tried to connect pin 2 of max232 from RFID reader to Pin 2 of max of controller it shows no output. However when I connected pin 2 of max232 from RFID reader to PIN3 of max of controller I am getting atleast some garbae value. Where is the catch? what i am missin? Please guide.
Thanking you.
Plz see this link
HTML:
http://www.pantechsolutions.net/microcontroller-boards/uart-interfacing-with-lpc2148-arm7-primer
to find some help I am not LPC2148 user so i cannot guide more; but in this link you can check your circuit.
you can try this one.
unsigned char k;     // declared as global
if(!(U1LSR & 0x01))     // valid data indication
     	card_id[k++] =U1RBR;
 return (0);
I have tried both of these, but none is working. Any other solution?
Thank you
Hi babar,
Thanx for your valuable time and suggestions. The problem is solved now.
Thanking you
 unsigned char card_id[11];
 unsigned char card_id2[11];//= {'1','2','3','4','5','6','7','8','9','0','1'};
  while (--b!=0);
  VPBDIV		= 0x2;
  U0DLL         = 0Xc3;				//Baud rate 9600
  U0DLM 		= 0X00;
  U1DLL         = 0Xc3;
 	unsigned char k,j;
	while (!(U1LSR & 0x01) && (U1RBR != 0x81));
	for(k=0;k<=11;k++)
     	card_id[k] =U1RBR;
		//U1LSR = U1LSR & 0x00;
	for(j=0;j<=11;j++);
		card_id2[k] = card_id [k+ 0x48];
	return (0);
  delay(30000);
	lcd_data(*CPtr);
    CPtr++;
	delay(20000);
void init_lcd(void)
  delay(200000) ;
  delay(100000);
  delay(100000);
  delay(100000);
int main(void)
	unsigned int i,k=0;
	init_lcd();
	init_serial();
	printlcd("A");
	while(1)
	receive();
		for(i=0;i<=11;i++)
			lcd_command(0x80);
			printlcd(card_id);
		for(k=0;k<11;k++)
			card_id[k]= '\0';
         /*for(k=0;k<11;k++)
			card_id[k]= card_id2[k];
		/*for(k=0;k<11;k++)
			lcd_command(0x80);
			printlcd(card_id2);
