RFID Tag UART Based Emulator
sakibnaz
Full Member level 3
Full Member level 3
Hi.
I need to make a RFID Tag Emulator which can take the ID as an input from Serial Port and Transmit the data through Coil (RF). So a RFID reader can read the ID which is coming from Emulated Tag.
I found some projects which are MCU based. I am mainly looking for a ready-made Chip which can take the ID from UART and Transmit through Coil over RF ....
Any advise please?
Regards.
It seems that AMS Austria has proposed a tag chip AS3953 fitting your need. Its datasheet can be found via the following website: **broken link removed**.
Hi Streamlet.
Thanks for your message. Actually I am looking for a chip to emulate 125KHz RFID Tag. Seems AS3953 is for NFC (13.56MHz). Do you know any chip for 125KHz?
Regards.
