[SOLVED] RF Tx-Rx INTERFACE WITH PIC MICROCONTROLLER
biswajitdas49
Member level 3
WEST BENGAL,INDIA
HI,
I want to interface a 433MHz ASK transmitter and receiver with pic16fxxx series microcontroller without any decoder and encoder.I want to connect directly a microcontroller pin with transmitter data pin.
Now my question- is it possible to send data stream through rf transmitter/receiver without using decoder/encoder?
Yeah you just use the micro and Manchester encoding code to send the data, RF is tricky at the best of times rf solutions do a 8pin pic that you send data through serial port then that sends all the data look on there for the Rf803e they do through hole and smt versions saves the headache
thank you for reply!
Actually I have WS-TX-01 and WS-RX-02 named TX/RX pair,so I want to know can I use EUSART or SPI for direct connection with uC?
As it very simple operation of reading and writing. Better use as a GPIO pin dont make unnecessary complication for this much easy circuit.
