nishal
Hi all,
I tried to send a data using RF transmitter (Part No ST-TR1100+TR from www.summitek.com.tw) fitted with telescopic antenna from a 60 ft high which is a metal enclosed room to the ground point. Transmission fails. Where as transmission from ground to metal room works pretty well.
What could be the reason for failure in transmission? is there solution?
I am using 433.92 Mhz, 1.2 kbps data rate, 2 FSK Modulation.
Thanks in advance.
Nishal
Thanks in advance.
Nishal
