Try Mitsubishi / Toshiba
The M57783 will give 7W at 150MHz There are others up to 50W or so so a 10W device should be easy enough to find.
They do modules that deliver about 20W at 1300MHz, not sure about high frequencies though.
Motorola used to make similar modules for up to 470MHz.
