RF PCB layout of a GHz range board
ashi
Member level 4
Egypt
I am working in the layout of tarnsmiter board working in the GHz range, can any on help me with resources about Rf pcb layout.
Thanks in advance
Re: RF PCB
You can use Ansoft Designer to design your board. You can also find some textbooks in this forum.
Re: RF PCB
In ADS you can use momentum to simulated the PCB and then use it in the circuit simulation
Re: RF PCB
Hello ashi,
Try AWR Microwave Office it has good layout editor with tight integration to Circuit simulation / Schematic editor...
It has good/ accurate models of surface mount components (Spice & sparameter files) of all the vendors
Easy to model board parasitics
Their are lot of tools which helps in quick RF PCB layout design such as – iCells, DRC, routing, optimization, etc…and it is fully integrated to Electromagnetic simulator...
---manju---
Re: RF PCB
Can any one recommend me a text or tutorial to read?
Thanks in advance
Re: RF PCB
Attached is document on RF and Microwave Basics Impact PCB Design....
Useful for PCB Designers...
---manju---
    ashi
