RF Module with Pic using Manchester Code
Korawy
Member level 3
Member level 3
Hi all,,
im intending to control DC Motors with a wireless communication.
i bought KST_TX01 & KST_RX806 kit which is RF Module working with ~ 433 MHz, I have used two PICs for this, P16F628A recceiver and P18F452A Transmitter.
I tried to make a simple transmitter - receiver program to switch on a LED, But i get NOTHING.
I used Manchester Code library in mikroC as it is easier than calling a Timer.
This is the Transmitter Code:
void main(){
char ADD;
PCON.OSCF = 1;
TRISB.F0=0;
TRISB.F1=1;
TRISB.F2=0;
cmcon=7;
PORTB=0;
Man_Send_Config(&PORTB, 0);
Man_Send_Init(&PORTB);
ADD=0b10101010;
for(;;){
if(PORTB.F1==0){
Man_Send(ADD);
delay_ms(17);
while(PORTB.F1==0){
Delay_ms(200);}}
and This is the Receiver Code:
char Signal, error;
char x;
void main(){
TRISB.F6=1;
TRISB.F1=0;
TRISB.F2=0;
PORTB=0;
x=0;
Man_Receive_Config(&PORTB, 6);
loop1:
Man_Receive_Init(&PORTB);
for(;;){
Signal = Man_receive(error);
if(error != 255){
if(Signal==0b10101010){PORTB.F1=1;}}
if(error==255){x++;}
if(x==200){
x=0;
PORTB.F2=1;
goto loop1;}}}
Just a simple Code to send one Byte, and when the receiver (P18F452) gets it , it powers on a LED.
Is there anything wrong with my Code?
Thanks in advance,,,
It is difficult with this type.
Try to transmit with serial communication and receive in other Pic and then give output to led
Reactions: Korawy
    Korawy
Thanks aameer,,
I did it using serial communication.. it worked but i have simple problems.
1- when i connect the receiver to 5v it drops to less than 3v, even if i connect only the receiver (without the micro).
2- when i transmit the data, the LED in the other side blinks if i press the button (which transmits the data) more than one time.
I hope i find help,, Thanks
