RF low power detector / low-cost
jabidof
Member level 5
qx5hayward
Hi everyone,
I need to develop a "low-cost" (<50$) "low-power" (-50dBm to 0dBm) detector working between 10MHz to 20MHz.
Any idea on this subject?
low power rf diode detector
A Diode power detector where u use the Square law characteristics of the diode will do for you, Problem is it measures up to -20 or -15 dBm , but if u use some 20dbm attenuators infront of your Detector u can extend it to 0 dbm that u require.
I'd use one of the Maxim's Tru-power detector devices. Simple and accurate, and already covers your dynamic range...
I have trouble finding the datasheet of the tru-power detector from maxim. Could you help?
Thks
You can use Analog Devices AD8307. There is a lot of projects with this chip on the web.
Thanks for the info. Maybe you already know some "good" links?
