RF Input power
Amr Wael
Member level 5
Hello,
I have been always a noob in RF/Microwave. When reading a datasheet for an attenuator/amplifier. There is always a rating for the maximum input power in dBm. I understand that power in watts = 10^((Pdbm-30)/10) but if I want to calculate the maximum voltage based on this power is it calculated based on the 50 ohm impedance?
Does this mean that a maximum input power of 10 dBm is equivalent to 0.707 Volts only?
Thank you very much in advance!
Yes 0.5Vrms
No, 0.707 Vrms. The power is referred to the RMS voltage value. If you want, instead, the peak you have to multiply by sqrt(2), that is:
10 dBm (10 mW) ==> 0.707 Vrms ==> 1 Vpeak
Further that might help:
\[ P ={10}^{\frac{P_{\mathrm{dBm}}}{10}} \cdot {10}^{-3} ~\mathrm{W}\]
\[P = \frac{{V_{\mathrm{RMS}}}^{2 }}{50 ~\Omega}\]
\[V_{\mathrm{RMS}} = \sqrt{P \cdot 50 ~\Omega}\]
BR
So
0 dBm = 1 mW
10 dBm = 10 mW
20 dBm = 100 mW
30 dBm = 1000 mW = 1W
-10 dBm = 0.1 mW
-20 dBm = 0.01 mW
10 dBm = 10mW on 50 Ohms system.
P = U x U / R --> U = sqrt(P x R) = sqrt(10 mW x 50 Ohms) = sqrt(500 m) V RMS = sqrt(0.5) V RMS = 0.707 V RMS
On a clean sinusoidal waveform: 1 V amplitude, 1 V peak, +/- 1V peak = 2V peak to peak
Klaus
