Rf basics,power amplifier basics
ram@419
Junior Member level 3
Hi every body....this is ram...iam new to rf field...it would be helpful if u please give me some guidence in this field......
Resolution Bandwidth: the resolution bandwidth filter or RBW filter is the bandpass filter in the IF path. Adjusting the bandwidth of this filter allows for the discrimination of signals with closely spaced frequency components, while also changing the measured noise floor. Decreasing the bandwidth of RBW filter decreases the measured noise floor and vice-versa. This is due to higher RBW filters passing more frequency components through to the envelope detector than a lower bandwidth RBW filters, therefore a higher RBW causes a higher measured noise floor.
Video bandwidth: The video bandwidth filter or VBW filter is the low-pass filter directly after the envelope detector. This filter is used to “smooth” the display by removing noise from the envelope. Similar to the RBW, the VBW affects the sweep time of the display if the VBW is less than the RBW. If VBW is less than RBW, this relation for sweep time is useful:
ST=K(SPAN)/RBW*VBW
Where ST is sweep time in seconds, k is proportionality constant, Span is the frequency range under consideration in Hertz, RBW is the resolution bandwidth in Hertz, and VBW is the video bandwidth in Hertz.
check this too
Spectrum Analysis Application Notes | Agilent
---------- Post added at 12:37 ---------- Previous post was at 12:37 ----------
Selecting a spectrum analyzer - Electronic Products
resolution bandwidth: The resolution bandwidth filter or rbw filter is the bandpass filter in the if path. Adjusting the bandwidth of this filter allows for the discrimination of signals with closely spaced frequency components, while also changing the measured noise floor. Decreasing the bandwidth of rbw filter decreases the measured noise floor and vice-versa. This is due to higher rbw filters passing more frequency components through to the envelope detector than a lower bandwidth rbw filters, therefore a higher rbw causes a higher measured noise floor.
Video bandwidth: The video bandwidth filter or vbw filter is the low-pass filter directly after the envelope detector. This filter is used to “smooth” the display by removing noise from the envelope. Similar to the rbw, the vbw affects the sweep time of the display if the vbw is less than the rbw. If vbw is less than rbw, this relation for sweep time is useful:
St=k(span)/rbw*vbw
where st is sweep time in seconds, k is proportionality constant, span is the frequency range under consideration in hertz, rbw is the resolution bandwidth in hertz, and vbw is the video bandwidth in hertz.
Check this too
spectrum analysis application notes | agilent
---------- post added at 12:37 ---------- previous post was at 12:37 ----------
selecting a spectrum analyzer - electronic products
thanx sir....for ur guidence...
I have some more doubts...with power amplifiers....some power amplifiers are not internally matched with 50 ohms....how to generate matching circuits for them using ads ..
Please guide me in design using ads...
Thanks and regards
ram
