powersys
Advanced Member level 1
For a single polarity power supply, a diode is usually inserted in series with the power supply to protect the system from being damaged due to reverse polarity.
How do we protect the system powered by dual polarity supplies (i.e. +/-15V, see below) from being damaged by reverse polarity (or wrong connections e.g. cases 2~6 below, assuming Case-1 is the normal/correct connection)?
