Resources for PCI system design
pepillo
Spain
I want to design a PCI system (based on a simple reference design), make the pcb, solder the components and test it.
Is it possible? where should I start? what technology do I use? where can I find the standard specifications, reference designs, etc?
it would be a university project.
pci board
The least thing we could say is that you want to do quite a big project..!
Well, most of the major FPGA manufacturers (Xilinx, Altera, etc.) offer many resources for PCI development, including dev kits, reference designs, etc. (using their chips, of course)
Good luck!
    pepillo
pci_b741x.pdf
Where should i start? I just need to implement something simple using PCI.
Should I start learning the standard or what?
ug072 zilinx
As Cyberblak mentioned,
It's not an easy job to make pci interface work if you do it from scratch.
look up xilink's altera's homepage...
If you're not familiar to FPGA design,
try to read the FPGA implementation software manual. (eg ISE)
buy a pci develoment board (eg. from avnet, not expensive)
configure PCI core into the FPGA and do what you want.
if you see the development board, all the question can be cleared.
    pepillo
pci system design guide pdf
First gothrough the PCI systems Architecture.
Then get referance code from opencores.
After understanding code u can...
Best of luck
    pepillo
simple pci interface
all right, I have read the specification and understand how the transactions work, but how can I implement a PCI board that I can plug into a computer and see how it comunicates?
pci system design guide +pdf
First simulate and verify the functionality of the code using proper test benches.
Select an FPGA which can fit your logic(code) and IO pins required.
Then synthesaize and generate bit file for that particular FPGA using the supported tools from the same FPGA vendor.
U need to designa a board which consists of the above FPGA and PCI signals brought out to the PCI connector. Then you can plug in to mother board. The board size, connector and routing details you can get from the PCI spec.
    pepillo
Re: PCI system design
But what about passive components? How do I select/place bypass capacitors, resistors, diodes, etc because I think the FPGA cannot be standing on the board alone.
Where can I download rules of system design to integrate the FPGA, MCU, Memory, and passive components in the board????
Thanks
PCI system design
as you may well understood, it IS a complicated design problem. and many points of dificulty exists.
me myself, had done the PCI core like specification(using the structure proposed in XILINXs PCI core datasheet). but then i fall in the problem of PCB design, driver development, i didnt had at least a good testbench for my design, i did not sure enough to plug my board to PC!!
then i suggest : concentrate ur efforts on one of these problems and solve the others with already exist solutions. for example find an evaluation board with appropriate PCI hardware interface....then at least u are sure that hardware is good and if somthing didnt work, u know where the problem is.....
huhh.... i finaly gave up and turn back to serial uart interface instead :D
    pepillo
Any book, application note, etc to learn the basics of system and PCB design? not pcb layout, but pcb design (bypass capacitors, resistors, diodes, power sources, etc)
Look in to the following link
    pepillo
i don no very much but this file...maybe usefull
    pepillo
hey,i found this in my documents....may it be more specific in this subject..
    pepillo
I cannot download the file, can you please send me a link or the document to my email? I think it's because of my connection (public library)
Thanks
PCI system design
    pepillo
Use the following link and save points for UG702 Xilinx PCB design guide
    pepillo
Find Useful pdfs from following EDA links
    pepillo
there are a lot of ASIC for PCI host and bridge, and also there are reference design, you can refer from them, it is quite easy.
for example, PLX Corporation.
h**p://www.plxtech.com
PCI system design
I think you need study more about PCI specificaion that could download free.
