sdram
- Joined
- Oct 10, 2012
- Messages
- 7
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,283
- Location
- Germany
- Activity points
- 1,325
I have simple register and getting single bit values from 5 state machines (all at one time). These values are stored in a register as std_logic_vector and has to be given as an input to another module. Once the output of this register is being processed in another module, the index in the register where there was a change (e,g 0 to 1), the value at that index should reset (e,g 1 to 0) and it should take no further input for that particular index (but there is constant input coming from state machines). Any suggestion, how it should be done?
Register code is:
Register code is:
entity fault_reg is
port (
clk : in std_logic;
rst : in std_logic;
reg_in : in std_logic_vector(NUM_PORTS - 1 downto 0);
reg_out : out std_logic_vector(NUM_PORTS - 1 downto 0)
end fault_reg;
architecture Behavioral of fault_reg is
begin
reg_impl : process(clk, rst)
begin
if rst = '1' then
reg_out <= (others => '0');
elsif clk'event and clk='1' then
reg_out <= reg_in;
end if;
end process reg_impl;
end Behavioral;
