[SOLVED] Resetting fuse bit in ATmega8
Full Member level 4
egypt
hii .
i write a wrong fuse bit for my atmega8 .
and i can't programming it via my usb asp programmer .
and in data sheet i find an parralel high voltage prorammer.
and i find this video
this high voltage can reset my fuse bit ? .
alexan_e
Administrator
Greece
Re: avr fuse bit problem
I suppose it is your idea of a joke...
5282604
Full Member level 4
egypt
thank you
i build a fuse bit doctor circuit
but it not reset my fuse bit chip ?
alexan_e
Administrator
Greece
So are you seriously asking, I thought you were making a joke with the burning chip video.
Do you know what is the fuse setting that you have applied?
The fuse bit doctor should fix any clocking or reset/isp setting problem.
You can also try https://www.edaboard.com/threads/105462/#post907231 , it uses a mega8 to unlock another m8 using parallel connection
5282604
Full Member level 4
egypt
thank you :grin:
my fuse bit like this
and it can't reset my avr by fuse bit doctor
alexan_e
Administrator
Greece
Your settings have programmed the mcu to a ceramic resonator and have disabled the reset pin (works as I/O).
Without reset you can only use the parallel programming to program the mcu
I haven't use the fuse bit doctor but if it didn't work you can try the circuit I have suggested or make a parallel programmer
