Require graphic lcd datasheet
Tajinder Singh
Junior Member level 1
graphical lcd datasheet
Hello everybody,
I have 240by128 graphic lcd based on T6963 .
i dont have its datasheet. After searching so much on the google i dont find the exact match.
only "744MO" and "ELECTROLITE 240128D" is written on the lcd.
my project is hold due to absence of this datasheet.
Any help will be appreciated.
lcd datasheet
Thankyou for your reply.
But i am asking about the pin diagram details of the LCD to make a working circuit.
As it has 20pin connector and i have checked with other datasheets that its VSS and VDD pin on the datasheets are not matching.
Waiting for your reply
glcd datasheets
Thats the datasheet of the controller chip - you actually want the datasheet pinout for the completed glcd module.
Although seraching for the the 'Electrolite ' shows nothing of use, if you look around for any other similar display using the t6963c controller there is a good chance the pinouts will be the same - but cannot guaranteee that !
http://www.purdyelectronics.com/pdf/AND1741.pdf
datasheet of lcd oriole
Generally, the LCD manufacturers follow same standard and only dimensions of the module vary.
Find this LCD from ORIOLE.
