Here I can see that you had trouble with HP6002A DC power supply....
I also have a problem, and I tryed to follow the link on1aag provided, but the service is no longer availabile...
So if tou have any schematics I would appreciate it very much if you coul send it to me via email or upload it here....
my specific problem is that both LEDs (for current and voltage mode) are ON always in local mode, and and voltage can not rise above 25V.
Inside I found one PCB track burned and broken, but I assume that the track burned for some very good reason and before repairing and turn it on I would like to investigate more about the cause track burned.....
I've found the schematics and can scan it for you if you haven't found it yet. I think the link is still awailable but it doesn't include all the schematics.
My power supply had a damaged HPIB board, I just had to put some jumpers to short it and now everything works perfectly.
I'm currently looking for the schematic for the HP 6002A. The documentation from Agilent's archives only has the schematic for the HPIB option. Any help would be appreciated.
Recently bought an HP6002A DC Power Supply - Option 001. I do not have either the OM nor the schematics. It is not working properly and I would like to fix it. Does anyone have a PDF of these? Know where to get them? Thanks
So if you have any schematics I would appreciate it very much
you send it to me email Okay!
