What does the following paragraph from the ICL7135/TLC7135 datasheet
entail doing, if the goal is to connect the ADC to an Armadillo (Raspberry Pi clone) please?
Attached are the Intersil and the TI datasheets for this ADC, the text content is identical in both, however the Intersil one has wiring schematics.
By serial transmission is it referring to SDI?
Would I be able to see the ANDed BUSY and CLOCK pulses on an oscilloscope, or is it not that kind of signal?
Would I need to use pigpio to attempt to implement this, or should I be able to copy, or try to put together, some Python code to read the count (and do the 10,001 subtraction)?
Does the datasheet mean that after sending the count the code will be quite complex to translate it to a useful number (e.g. 25ºC, or ... 2.65V, etc.)?
I've got the ADC on 125kHz, and checking the Broadcom datasheet for the chip on the "Pi" it looks like it can work in the MegaHertz range, so I think stuff to do with sampling rate shouldn't be an issue?
I've never done this before, so I basically have no idea what my main objectives should be, and what I need to use/study a little first (e.g. SDI or what?).
Thanks.
