Request for Simulation Software for Vacuum Tube !!
javabean40
Junior Member level 1
earth
vacuum simulator software
Hi, I am learning to design vacuum tube amplifier. Can someone help me to get this? Thanks in advance. :oops:
vacuum simulation software
You can use any spice simulator. You will find some models and theory at
h**p://www.duncanamps.com/spicevalves.html
vacuum tube simulation softwares
Hi
As papyaki said you can use any spice simulator, at duncanamps there is explained how to use the models in /P*s*pice. There are different models some for berkley spice and some for the /O/*rcad. If you run into problems I try to help, if I remember how I did it :)
In circuitmaker there already exists some tube schematics and models. Check there first.
If youl ike you can check for more info here:
http://home.wxs.nl/~frank.philipse/frank/frank.html
http://www.normankoren.com/Audio/index.html
http://www.audiodesignguide.com/index.html scroll down
http://digilander.libero.it/paeng/pae.htm
Good luck
and if you need help PM me.
Hi, friends, thank you all for your precious info and help. thanks again!!
