Jester
Full Member level 6
Can anyone spot any errors or ways to improve this circuit?
Battery is 12V, 10A-Hr lead acid
Load is < 0.5A
Needs to work outside in the dead of winter and in the heat of summer
Battery is supposed to be isolated if both supplies fail and the battery voltage drops to about 10.5V (perhaps I should bump it up to 11V?
The load is connected between Vbat and ground (small black triangle)
U8 http://www.ti.com/lit/ds/symlink/bq24450.pdf
U3 **broken link removed**
Q44 http://www.irf.com/product-info/datasheets/data/irlml6344pbf.pdf (Is this big enough?)
Thank you.
Load is < 0.5A
Thank you.
