Req Help - fully differential op-amp
arpit_655
Newbie level 5
Hi all,
i`ve designed a gain boosted folded cascode fully diff op-amp with 100db gain & 700MHz UGB.
i tried with putting differential-to-single-ended stage but it was causing the op-amp to be highly Unstable...
could someone tell me how to configure a fully differential op-amp as voltage follower (unity gain feedback).
Waiting for a quick reply..
Regards.
eda4you
Full Member level 5
Make simulation and make a bode plot. (Look also for a rebound of the phase). You should have at least 60° phase margin.
arpit_655
Newbie level 5
i have 70 deg of phase margin while taking differential output....
but when i put next stage to get single ended output then phase reached -220 deg
making the op-amp highly unstable....
is it possible to use a fully differential op-amp as a buffer in chage scaling D/A converter... plz suggest a way...
Btrend
Advanced Member level 1
do u include ur next stage as load while in runing AC simulation of ur differential amp ?
arpit_655
Newbie level 5
next stage is a differential amplifier with active current mirror...
