[req:] AVR MSK soft transciever
aNdreiBuuu
Full Member level 4
moon
I want to implement a simple, low data rate (1200-2400baud) MSK communication between 2 tiny AVR. (the carrier can be anywhere between 9KHz and 20KHz)
Can you provide some C source code for MSK software modulation/ demodulation?
I want to use only the controller without other active components or circuits.
Thanks in advance,
Best Regards,
//a
HI
8 bit AVR will find it hard to process FSK or MSK data modulated carrier - try to use AVR32 bit or ARM cortex (M3)
Basically you will need to decode A bi-phase signal using DFT algorithm
Google DFT & Grotzel to learn more
Go to TI site and search for MSP430 there is an fine application note for modem design using FSK and code written in C language
All the best
Bobi
The microcontroller specialist
    aNdreiBuuu
